What is the output current specification of UCC21520DWR at 350KHz? There is no relevant curve in the datasheet. The specification value in the datasheet is tested at 1KHz.
Best regards!
Ethan
Best regards!
Ethan
Hi Ethan,
Here are some equations that you can use to calculate your peak output current specifications, depending on your application:
For additional context, see pages 25-26 in the UCC21520 datasheet, which further explains these equations along with examples. Let me know if this helps.
Will
