Other Parts Discussed in Thread: LP5562
I would like to use the new LP5810 to drive an RGB LED as well as an independent green LED.
However, I need a particular functionality and I am not sure if it is available:
- I would like to "program" the driver so that at startup, in standalone mode without MCU intervention, we can preprogram the LED output (for example: RGB off / green LED on only). When the system is completely reset, the pre-programmed settings will be available directly.
It seems to have programmable internal memory according to the Texas Instruments search tool, but I am not sure about the possibility of this functionality.
Could you confirm this for me?
Thank you and best regards,
Maxime
