Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TPS23841: TPS23841
Part Number: TPS23841
poe_IC_TPS23841_descripencies.docx
Here is the  detailed report on what issues we are facing with TPS23841.
Kindly go through the same and provide us the solution to fix these problems at the earliest.
  • Hi Vaishnavi,
    1. Please see attached Reference Design for 8-Port Application using TPS23841.
    2. Please self check schematic with reference design and send PDF of schematic for review.
    3. The A/D conversions are documented in the datasheet, please see attached below:
    4. Can you read the faults being reported from Port 3?
    Brandon
