Other Parts Discussed in Thread: TPS62933
Hi Teams,
I am designing with TPS62933 and have some questions about the caps placement at the input and output.
According to the description in datasheet layout guidelines, we'd better put small value cap as close as better to the IC pins.
But I found that on the EVM, at the input, small value C9 is very close to the Vin, but at the output, small value C5 is not so close to the GND, but very close to the output connector.
Could you kindly help to clarify in the theory level to help me understand, do you have any appnotes addressing this part? If so, it also helps.
BRs,
Marsh
