Other Parts Discussed in Thread: LM74800-Q1,
Regard using the En pin for disabling the Ideal Diode.
In case that En='0' which means disabling the Ideal Diode Gate drive and put the Ideal diode in Shut down mode. The N-channel MOSFET Vds is still keeping the same value as before. Then what we get is that FET tunnel is closed while all the Vds voltage is now falling on the N-channel FET bulk diode like a forward voltage while gate is closed. Is that a legal state where the FET diode is in high forward voltage Vds=12v of a battery for example while its gate is lock and FET tunnel is closed ? Won't there be a leakage current through the bulk diode? It is actually a diode under high forward voltage of 12v. It sounds suspicious.
BR,
Ohad
