The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TPS6594-Q1: I2C does not work well
Part Number: TPS6594-Q1
Other Parts Discussed in Thread: TDA4VH
    What can make the device I2C not work well? There is one device that shut down suddenly and I want to know what happened by reading I2C register. But the read value is random and all address is the same. So I think there is something wrong with the I2C. What should I check next? And WCCA is not UV or OV.
  • Hi Zehui,
    Would you be able to provide more information about device OPN (orderable part number)? Also to checking VCCA, VIO, VOUT_LDOINT and VOUT_LDORTC voltages is must to have.
    Are there scope shots about I2C transaction? Is I2C working normally when device is powered?
    Br, Jari
  • Hi Jari,
        TPS6594133A-Q1 for TDA4VH. I already find there is some noise at VCCA when TI-DL is running. And when change the LDO2 threshold from 5% to 10%, no shut down anymore. It makes sense that LDO2 is 3.3V and when VCCA is out of 5% LDO2 has an error. But I don't understand why I can't read register by I2C. According to experience before,reading INIT register is a good way to find the reason. I2C is working normally before shut-down and after shut-dwon I don't see any difference of waveform except response is random and wrong.
