Other Parts Discussed in Thread: , TPS25751, TPS25751EVM
Hey I want design a battery charger using BQ25756 in that I want limit the charging current to 3.5 Amp Max and i want to indicate charging ststus using led.
Hello Sarabh,
Thanks for your interest in this part. I have few questions about this.
What's your input voltage and charging voltage?
Do you have any input current limits and will you be charging from a USB adapter?
Ethan Galloway
For input I am using 100W adaptor so input is 24V Dc and charging voltage is 25.3 V
Hello Saurabh,
I think the BQ25756E would work well for your application.
If you are using a USB 100W adaptor, you can use the TPS25751 to set and request the USB power contracts. If you use the BQ25756E EVM with the TPS25751EVM, you'll need to make sure to use a 5mΩ input sense resistor.
Ethan Galloway
