Other Parts Discussed in Thread: BQSTUDIO,
After learning cycle I create one otfs-file with the bqStudio.
I follow the same procedure given in the document /cfs-file/__key/communityserver-discussions-components-files/196/SLUA703-SmartFlash-OTP-Programming-AR-Final-EPDF-20May2014.pdf
Now I try to program the BQ27411-G1C with the software SmartFlash (V07.0) but the thing is I am not able to complete the programming.
Errors:
06/27/2024 6:31:18 PM >> ERROR: Received NAK 53 - NAK received.
06/27/2024 6:31:18 PM >> ERROR: Received NAK 57 - NAK received on I2C Write.06/27/2024 6:31:18 PM >> ERROR: Received NAK 58 - NAK received on I2C Write.
06/27/2024 6:31:22 PM >> ERROR: Programming failed!
After this error the battery monitor get crashed and It was not detected by the smartflash application or bqstudio. The battery monitor is detected only after removing and reconnecting the battery.
What is the reason for this error? Any different way to flash golden image to the battery monitor bq27411-g1.
I have uploaded the .gg file, .otfs file, smart flash logs and screenshots of bqstudio during process in the given zip file.
