Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
LM25185: LM5185EVM-SIO Altium project pcb, how AGND and PGND are connected ?
Part Number: LM25185
Other Parts Discussed in Thread: LM5185EVM-SIO,
Hi e2e
Could you share the LM5185EVM-SIO Altium project pcb?
I ask becouse in document SNVU869 is not cleared for me with this information or I not found it on that document. For spec. LM25185 on basic schema I see AGND and PGND are connected but in which point and how ?
  • Hi Damina,
    Thank you for posting.  Since I will need our PCB craftsman to clean the file before sharing, let me see if I can answer you in this short reply.
    The AGND and PGND are connected through the under pad, which I highlighted in below:  the trace from the AGND pin to the under-pad.  PGND pin is beside the C14 label.  This small trace--which is represented by the Net-Tie on schematic--makes the single point connection between AGND polygon and PGND plane.
    Hope this helps.
    Youhao
