Part Number: TPS628501-Q1
Hell experts,
Let me confirm the possibility of the TPS628501-Q1 outputting a negative voltage.
Synchronous DC/DC converters can output negative voltages in some cases.
Does the TPS628501-Q1 generate negative voltage?
For example, when a charge remains in the output capacitor,
there is a case where a negative voltage is generated when the power supply is started again and turned on from the switch on the Low side.
BR,
Kentaro
