I've used UCC21550ADWR half bridge isolated gate driver IC to drive the MOSFET. Here I'm facing some issue while driving. . Below are the attached schematic which I'm using to drive the half bridge MOSFET.
Issue : I'm using 3525 IC for PWM generation and during ON time both PWM is ON from 3525 IC (Waveform attached) but in driver UCC21550 side, only Lower pulse is ON but upper pulse is off.
Kindly check the schematic, Let me know if any changes required in components value.
Testing conditions:
1. Check with system (connecting both driver signals (OUT A & OUT B same as VSSA & VSSB to MOSFET)
2. Changed the values of DIS and DT pins - No result
Your early response is valuable for me.
Thanks.
