Other Parts Discussed in Thread: BQ2057, BQ25170
Hello everyone,
I have a problem with the BQ2057SN not BQ2057C.
I am using the IC on my board to charge a LiPo battery. One charging cycle ran without any problems but since then some problems occur.
It started with a relatively full battery (3.95V) that could not be charged (LED on status pin no longer lit) but a battery that was discharged (about 3.5V) could be charged.
Now, however, no battery will charge, regardless of whether it is still relatively full or already discharged.
I also tested whether only the LED/status pin is defective, but the battery had no significant change in voltage after 15 minutes.
I switched on the board once during the last charging cycle, so the system behind the charging circuit was also energised. Could this have damaged the BQ2057SN or where could the problem be?
Leon
