Hi All,
Tried Simulation below circuit & observing different behavior in graph as shown below.
START UP GRAPH:
STEADY STATE GRAPH: Voltage dip observed here but not seen in start-up case. Could anyone clarify it?
Dharma
Hi All,
START UP GRAPH:
Dharma
Hi Dharma,
Depending on what your initial conditions are the device needs to have VOUT, CIN, IOUT charge up so that they are in their final states. If they aren't the the device as to reach those conditions before the data is realistic.
I there should be a "start taking data after X time" I'd recommend that for steady state simulation.
Andrew
Thanks Andrew.
In steady state model i understood the voltage dip is due to missing initial conditions and in Start Up model the voltage dip is not happening due to the presence of initial conditions, am i right?
In Onboard can i expect this dip in voltage?
Dharma
Can i expect this
