LM5156H-Q1: LM5156HQPWPRQ1
Part Number: LM5156H-Q1
Hello Team,
I am working on LM5156HQPWPRQ1 PWM controller IC. And I have seen that IC is malfunctioning.
when voltage is given externally at EN (pin 14), seeing voltage at BIAS (pin 1) pin. So, I want to understand is there any circuit connected b/w EN and BIAS pins internally. If yes, could you provide that circuit details or could you explain the reason for that voltage at BIAS pin.
Thank you,
Tejasri.
