BQ30Z554-R1: Permanent -CB threshold and delay
Part Number: BQ30Z554-R1
Hi E2E,
Please explain in detail the specific working behavior of the three parameters CB-Max Threshold, CB-Delta Threshold, and CB-Delay as described in the TRM page100.
Something like If CB-Max Threshold is set to 120, does it mean that if balancing cannot be completed within 240 hours, it will trigger a PF?
I need more detail about these paramerters.
www.ti.com/.../sluua79.pdf
  • The gauge throws a CB PF Alert and eventually CB PF Status if:
    * PF Status: The max. cell balancing time takes more than 2xCB Max Threshold seconds
    * PF Alert: The max. difference between cell balancing times (max. time - min. time for all cells) is more than 2xCB Delta Threshold seconds
    * PF Status: The gauge was in PF Alert for >= CB Delay cycles.
