Other Parts Discussed in Thread: GPCCHEM
The discharge will suddenly drop from 70% to 50%. What is the reason for this?
Currently, the TI database uses the chemical ID 5377. Could you please check if this ID is appropriate?
The image below taken from the bq27426 Technical Reference Manual shows the three chemIDs you can select for this gauge. In order to determine which of the three chemIDs is the best match, you can use the GPCCHEM tool.
Robert.
