TPSM365R6: Recommended land pattern issues. What is the correct footprint?
Part Number: TPSM365R6
I have a similar question to the following thread. The thread was marked as resolved, but I am still having issues understanding the recommended footprint.
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1398534/tpsm365r6-solder-mask-layer-check-and-max-voltage?tisearch=e2e-sitesearch&keymatch=TPSM365R6#
The datasheet specifies that NSMD (non-soldermask defined) is the "preferred" style. However, the drawing appears to use SMD style. For example, how is pin 10 supposed to be laid out in an NSMD style? The drawing also has a lot of issues where it is almost impossible to calculate the location that the larger pads without lots of backcalculating.
Is the drawing just mistaken that NSMD pads are recommended and should instead require SMD?
