Can you please share the compensation circuit design document?
Note: I'm using inductor current sensing in my schematics.
Hi Swathi,
Do you mean the internal calculations that are in the document? We are not able to give access to those. You can however refer to the application section of the datasheet (section 10) that should give you all the equations should you want to calculate these parameters yourself. I will note that these will be identical to the calculator shared. The calculator is given for your convenience so you can quickly implement the LM25143 into your solution.
Thank you,
Joshua Austria
Hi Joshua,
The configuration that i'm using is single output interleaved operation with inductor current sensing. In the section that you have referred, The calculations are shown only for the shunt current sensing method. Please check and let me know your comments.
Hi Swathi,
We are unable to share the internal calculations given in the calculator apart what is given in the calculator or in the datasheet. I will note that section 9.3.14.2 of the datasheet has some relevant equations for inductor current sensing that might help with what you need.
Thank you,
Joshua Austria
