Part Number: LP5910YKA18EVM
Other Parts Discussed in Thread: THS3120EVM, LM317
Hi Team,
We would like measure LDO PSRR. For our measurement, we would like to use scope to check.
1. First setup, we used THS3120EVM to generate the DC+AC voltage signal. And remove the Cin of LP5910EVM like training video said.
For the scope measured results, (CH1 yellow is the input/ CH2 blue is the output, using AC coupling):
200mA Load
300mA Load
You can see there are spikes on input side.
2. Second setup, DC powering by linear regulator LM317
Oscilloscope measured results (CH1 yellow is the input/ CH2 blue is the output, using DC coupling):
100 mA load:
200mA load
And my question is that
1. How to mitigate these spikes?
2. Do we have LDO measurement environment can be referred? I found the below training video, but would like to double check if we have updated setup.
https://www.ti.com/zh-tw/video/4459556475001
3. Our purpose is that input maybe 10kHz AC signal 1Vpk-pk and see may 0.1Vpk-pk 10kHz AC signal. And we can get PSRR = -20dB at 10kHz.
Roy
