TPS54160A: Ambient temperature effect output voltage
Part Number: TPS54160A
Hi Team,
Ambient temperature effect output voltage, are there any rule cause can be improved?
  • Hi Kevin,
    This could be due to measurement issue. Can you check the output voltage right across the output capacitor?. Also, it is expected that Rds(on) of the FET is higher as the temperature increases causing the output voltage to drop at higher load current.
    Nitya
