TPS22950: Reverse current block.
Part Number: TPS22950
Hi TI Power Switch Guru,
I am looking at an alternative for diode + PMOS and thus looking at TPS22950 for an wearable bidirectional charge and discharge application That requires current lim and reverse blocking in both directions until commanded.
As you can see in this example schematic, i have a Regulated output leg, a bypass leg to output directly from VSYS, and a charging leg for TPS22950.
VOUT could be lower or higher than VSYS.
Do you foresee any issues with this approach?
