Other Parts Discussed in Thread: LM3414,
Dear Texas Instruments Support Team,
I am currently working on a project involving the control and driving of UV LEDs using the TPS92200D1DDCR LED driver. This driver requires an external sense resistor to set the LED current. However, in my application, the PCB layout is constrained to a single layer, and the trace impedance added to the sense resistor is significantly affecting the overall LED current, leading to a reduction in the output power of the UV LEDs.
To overcome this, I searched for LED drivers without the need for an external sense resistor and found the LM3414MRX/NOPB. However, I noticed that the block diagram of the LM3414MRX/NOPB includes an internal sense resistor. I am concerned that this internal resistor might still be influenced by the trace impedance in the same way as the external resistor in the TPS92200D1DDCR, leading to similar issues with LED current and output power.
I would like to request your expertise in understanding the following:
Trace Impedance Effect on LM3414MRX/NOPB: How does the trace impedance on a single-layer PCB affect the internal sense resistor in the LM3414MRX/NOPB, and what impact does this have on the LED current regulation?
Solutions for Mitigating Trace Impedance Issues: Are there any recommended solutions or design guidelines for minimizing the effect of trace impedance when using these LED drivers? Specifically, I am looking for methods to drive UV LEDs without experiencing current reduction due to trace impedance, ideally without using an external sense resistor.
Alternative Solutions: If the internal sense resistor of the LM3414MRX/NOPB is also susceptible to trace impedance issues, could you suggest alternative LED driver ICs or design approaches that would be more suitable for driving UV LEDs in my application without being affected by trace impedance?
Thank you for your assistance. I look forward to your guidance on resolving this issue.
Mohamed Obaid ,
QUANTTRONIX LLC
