Part Number: LMR38025QEVM
Hi team,
My customer evaluated LM38025 for their new design. but they change some settings as below.
Vin=60V
Vo=12V and change the inductor to 10uH or 22uH. (spec as below)
The customer tested short circuit test 2~3 times then EVM damage.
They use a 200R as load and parallel a switch as a short test device.
After 2~3 times then IC damage. test waveform below. you will see a spike after protection occurs.
Customers think IC damage caused the spike. Could you give some suggestions? thanks
CH1 is Vin
CH2 is Vo
CH3 is Io
