TPS737-Q1: Inquiry for Package Outline (DRB0008A, DRB0008B) of TPS737-Q1
Part Number: TPS737-Q1
Hi, TI expert
I am trying to do a board layout using TPS73733QDRBRQ1.
However, when I checked the datasheet, there are two types of outline information: DRB0008A and DRB0008B.
When comparing DRB0008A and DRB0008B, the 'EXPOSED THERMAL PAD' part is different.
Which one is correct, DRB0008A or DRB0008B?
Which outline should I apply for PCB layout?
Please check. Thanks.
    Thank you for your packaging question.
    From the datasheet is seems that the generic DRB package would be the DRB008B, unless you specify a particular interest in ordering the A package, then you would receive the B package.
    I will ask our packaging team to confirm this for me and get back to you as soon as I hear back.
    Hope this helps!
    Hannah
    After talking with packaging, it seems that the package that will be shipped to you is the DRB0008A package type.
    Hope this helps!
    Hannah
