Other Parts Discussed in Thread: TPS25221, , BQ25756
hello,
The customer needs to charge the supercapacitor with an input voltage of 20-30V, and requires the chip input voltage to be above 40V, the charging voltage is 0-20V, the capacitance of the supercapacitor is 150F and the charging current is about 2A. The customer referred to the BQ25798+TPS25221 solution, but the input voltage of BQ25798 is relatively low. Is there a better solution recommend?
Thanks!
