Part Number: TPS25830A-Q1
Hi TI team,
Please review the customer's schematic.
TYPE-C USB charger with a 15W 1 port specification.
Schematic delete.
Hi TI team,
Schematic delete.
Hi CHO,
The schematic looks good. Here are a few suggestion:
1. R13 is the current sense resistor. The recommended voltage across RSNS under current limit should be approximately 50 mV as a compromise between accuracy and power dissipation. 5mOhm could be too small.
2. Pin 9 RT/SYNC is floating in this design, is this on purpose? Generally a proper resistor is suggested here.
3. A 10-uF cap is recommended to be placed in parallel with C28 as the C_BUS.
4. Please consider adding pull-down resistors for DP/DN near the output connector.
BR,
Ke Wang
Hi Ke Wang,
Thank you for your support.
Please review the revised schematic.
Schematic delete.
- Instead of 15mOhm in the data sheet, we applied 10mOhm in the mass production specification. Is there any problem?
- Modified it to use 49.9kohm (400khz).
- The VBUS on the USB TYPE-C side was moved to the appropriate C28 side.
- DP, why do I apply pull-down resistance to DM?
Usually, only damping resistance and C and L were applied, but I wonder why.
Hi CHO,
Thanks for your reply. Currently I don't have additional suggestions for the schematic. For your questions:
- Instead of 15mOhm in the datasheet, we applied 10mOhm in the mass production specification. Is there any problem?
-> As long as the voltage drop across this resistor is around 50 mV it's fine. 10mOhm looks good to me.
-> The USB spec specifies 15kOhm pull-downs for DP, DN for a host/hub port, please check if you need to define the role of the board and decide if the 15kOhm resistors are required.
BR,
Ke Wang
