POWERSTAGE-DESIGNER: Mismatch between SLUA560D and Power Stage designer PSFB design
Part Number: POWERSTAGE-DESIGNER
hi,
As per SLUA560D & SLUC222D, the magnetizing inductance and output inductor calculations use inductor switching frequency (i.e. 2 times mosfet switching frequency).
However the POWERSTAGE-DESIGNER takes FET switching frequency as input and uses the same equations given in SLUA560D --> WHICH gives double magnetizing inductance value, and that seems wrong.
can you please confirm if the understanding is correct and POWERSTAGE-DESIGNER needs rectification?
