TPS543C20A: EN PIN VIL Spec
Part Number: TPS543C20A
Team,
Kindly check on the EN Pin logic VIL and VIH spec in the datasheet, I couldn't find it in the published datasheet. Thanks!
Qiang
  • Hello Qiang,
    The EN pin logic high and low are found in the Electrical Characteristics section of the datasheet (screenshot attached below). The typical threshold is 1.6V with a 300mV hysteresis. This means the high to low threshold is 1.3V and the low to high threshold is 1.9V
    Britton
