The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TPS62827: Negative current limit of Low Side FET
Part Number: TPS62827
Hi Team,
How do we understand the negative current limit in the datasheet?
Thank you,
Yishan Chen
  • Hello Yishan,
    this parameter is important for forced PWM applications, as described in 7.3.5
    In forced PWM devices, a negative current limit (ILIMN) is enabled to prevent excessive current flowing
    backwards to the input. When the inductor current reaches ILIMN, the low-side MOSFET turns off and the
    high-side MOSFET turns on and kept on until TON time expires.
    In case of low output currents, forced PWM causes negative current flow through the low side FET.
    I hope this answers your question.
    Regards, Werner
  • Hi Werner,
    Thank you for you support.
    Maybe go a little be deeper, So how do we calculate the negative current during in the operation? What is the relationship between the load current/Switching frequency and inductor and other specification?
    How customer know if they will not exceed the limit here?
    What is the switching frequency in FPWM mode?
    Thank you,
    Yishan Chen
  • Hi Yishan,
    Equation 6 in the D/S calculates the ripple.  If you replace Iout,max with your minimum load current (usually 0A) and subtract 1/2 of the ripple, you get the minimum negative current in your application.
    Chris
