CSD17303Q5: PCB Pattern
Part Number: CSD17303Q5
Hi
If you look at the actual parts, I think the marked part should also have a pattern, but it's not in the recommended PCB pattern.
Please make sure it's right.
  • Hello David,
    Thanks for your interest in TI FETs. I can confirm that this is the correct recommendation. Please see the detailed package drawings including recommended PCB pattern at the link below. This is also available in the product folder under the Ordering & quality tab. This drawing matches the recommendations in the datasheet and does not extend the large thermal pad out to the small "wings" on the sides of the thermal pad.
    https://www.ti.com/lit/ml/mpss011d/mpss011d.pdf
    John Wallace
    TI FET Applications
