Part Number: TPS25830A-Q1
Hi team,
The customer used TPS25830A-Q1 in the A port. The CC on the TYPE-C to TYPE-A harness had a 5.1K ground resistance. The test found that when the harness was connected first and then powered on, VBUS had output, but it disappeared after hot plugging. When VBUS was normal, plug and unplug the C to A cable. During the test, no other device was connected to the A port.
Is this normal? Does it support hot-swap handshake recognition?
