thank you in advance for your support!
For our application we need to speed up the startup of our batterypack.
We would like to have less than 100 ms activation time.
In the datasheet the FET transistors will get enabled only after 280 ms.
Is it possible to enable the fets earlier through an command?
When can the fets be activated at the earliest?
Best Regards
