Other Parts Discussed in Thread: UCC21550-Q1
I’m experiencing issues with a PFC design connected to the grid, where the SiC MOSFETs are getting damaged.
After some investigation, we found that the output push-pull from the gate driver is short-circuited in some cases from VDD to OUT.
We have both PWM signals and a Disable pin coming from the microcontroller, but the timing for the Disable pin is not controlled because it can also be triggered by hardware protection.
According to the datasheet, the input should not be switched from ON to OFF during the turning ON process.
Does this mean the only way to work with this gate driver is by using an FPGA to control the turning ON/OFF and Disable of multiple sources?
Do you have any other part numbers to suggest that could handle this condition better?
Thank you.
