Other Parts Discussed in Thread: TPS65131
Dear TI Engineer,
During our testing we found that when the input 3.6V power supply (PERIF_SWR3V6) is boosted by TPS65131 to a 5.5V output (OLED-AVDD5V5), there is a short 3.6V voltage step in the output waveform. The voltage step will last about 0.5ms and then output the normal 5.5V. The waveform is as below:
The schematic is as below:
Can you help confirm if this waveform is normal? And is there any suggestion to improve this issue?
Kind Regards
