The SEE test report for the TPS73801-SEP shows that it was tested up to 43MeV-cm2 /mg.
Was this part tested up to 75MeV-cm2 /mg? And do you expect it to fail at that level?
Thank you.
Thank you.
Hi Brendon,
This part was only tested up to 43MeV-cm2 /mg, so we cannot comment on expectations beyond that. If you're looking for a part that has been tested and characterized up to at least 75MeV-cm2 /mg, then I would recommend the TPS7A4501-SP, which is largely equivalent electrically.
Sarah
