in TPSF12C1 Excel tool, there is a sheet of "CM Choke".
1. can I input my choke data here?
2. what calculation will use these data? becuase those data change, but not find something change on the sheet of "Design the AFE circuit"?
Hi Alan,
yes, you should input your CM choke data into the "CM choke sheet" in excel calculator.
The calculator will use this data to check how to adjust other component values for stable loop response, INJ pin waveform and gain performance.
Thanks and Regards,
