Hi Team,
We are using the TPS65185 PMIC for our EINK 10.3" Display (EC103TH2). The typical voltage of the VGL(Gate Negative supply) is -22V. From the datasheet it is noted that minimum voltage of VEE_IN(input supply for charge pump) is -20V. Is it possible to generate -22V? What is the maximum voltage that can be achieved from TPS65185? Could you please comment on this? The voltage level of the display is provided below for your reference.
