TPS659128: PMIC survey
Part Number: TPS659128
We wants find below replace part, I found TPS659128 should be suitable but we need can write default setting into PMIC OTP.
May I know there have any minimum run rate requirement or fee for OTP? Thanks!
  • Hi Jeff,
    It is unlikely we would be able to make a custom OTP for the TPS659128 device, as this is an older device, and the business case would have to be very large.
    I would contact your marketing representative directly for more details on the specific requirements.
    Instead, I would propose looking at the user-programmable TPS650861, which would enable you to write and burn the default settings yourself.
    Or maybe the user-programmable TPS6521905 for lower current applications.
    Sarah
