Hi everyone,
I am using the LM3409HV driver to control LED current. The system generally works fine, but I am encountering an issue when I attempt to adjust the PWM signal (either increasing or decreasing the duty cycle). During these adjustments, the current output fluctuates instead of smoothly tracking the PWM signal. In some cases, the current changes erratically in steps and not fluently like the PWM.
The PWM signal itself appears to be stable and functioning as expected, but the current behavior does not consistently follow the PWM adjustments smoothly.
Could you provide any insights as to why the current might behave this way when adjusting the PWM signal? Is there something in the circuit design or configuration I might be missing that could cause this intermittent behavior? Find attach my schematic and a video of the signal, where in yellow you can see the PWM signal and in purple the current output.
Thank you for your assistance.
