Other Parts Discussed in Thread: UCC28070
I'm designing a PFC controller. I choose it because I'll need ~3.5kw output power and it supports running multiple controllers synchronized. I need my output voltage to be adjustable between 250-350volts, (120vac input). At first, I figured I could just adjust the feedback voltage divider to Vsense, but the datasheet mentions that the resistor divider network must be identical between Vsense and Vacin. So should I just vary Vsense, or both or is there a better way?
Thanks for any help...
