Part Number: TPS563200
Other Parts Discussed in Thread: TPS563240
Hi
Would it be OK if we set a voltage between 0.6 and 1.6 as the enable voltage?
is there any definitive information such as low between 0.6-1 and high between 1 -1.6?
There is a interruption test, we saw that the output voltage was not interrupted without the Ven voltage falling below 1.2, However, when they make such an adjustment, in the case of stby in our product 12 volts fall to 8 volts, the Ven voltage comes to 1.33v levels,
The product is working properly but because a non-speculative situation occurs, the test group returns as NOK, Is there any detailed information for VEN such as TPS563200 Richtek below?
TPS563200 spec:
RT6213B:
