BQ25172: Want to change VHOT
Part Number: BQ25172
Hello team,
Is it possible to change the VHOT to 60℃?
It is typically 45℃ on the datasheet.
Kei Kuwahara
  • Hi Kei,
    The TS function was designed to work with a 103AT thermistor.  If you find a different thermistor with resistance at 60C x I(TS_BIAS) below to give 188mV, then it might work.  But then the COLD and COOL values might be off.
    Jeff
