I used the webench power designer to generate a schematic for 3.3V/6A output with maximum efficiency.
It generated a schematic which matches an adjustable output voltage configuration.
According to the webench design, the BIAS pin should be connected to the GND.
According to the datasheet of LM706A0, for adjustable output voltage configuration it should be connected to VOUT pin.
Which source should I follow?
Thanks!
Roy
