Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TPS61391: TPS61391
Part Number: TPS61391
Dears,
At present, my customer wants to achieve an adjustable negative voltage range of -40V~-60V. The initial evaluation of the solution in the following document is OK, but the function of adjustment does not feel easy to implement. One of the customer's initial solutions was to inject a voltage into the node of the FB. The customer wanted to know if this solution would work, and if so, a simulation model would be available. Or do you have any good plans to recommend?
Many thanks,
Arabella
