Part Number: TPS25983
Other Parts Discussed in Thread: TVS2700, TVS2200, TPS25948, TPS2663
I'm working on a compact board that uses both 14V and 24V rails. It has three voltage rails, one for 24V and two for 14V and needs protection against over-current, over-voltage, under-voltage, and possibly reverse current.
I'm considering using three TPS25983 devices as fuses (one for each connector) with reverse-blocking MOSFETs. I'm also planning to add TVS diodes on the outputs for transient and ESD protection. The 14v rails have a max current of 6 amps and the 24v rail has a max current of 4 amps.
Here's my issue:
24V Rail Protection: The TPS25983 has a max voltage rating of 30V, which doesn't leave much room for TVS diode selection. I considered the TVS2700 flat clamp, but its max clamping voltage is 32V—above the TPS25983's limit. However I think The 14V rails are fine with the TVS2200.
Space Constraints: The board is very tight on space, so adding ideal diode controllers and MOSFETs instead of the TPS25983 might not be feasible because of size.
It seams to me the issue mainly arises when the reverse-blocking MOSFET is on. If it's off, the TVS2700 would be acceptable due to the MOSFET's higher voltage rating.
My Questions:
Any suggestions for protecting the TPS25983 from transients at 24V, considering its 30V max rating of TPS25983?
Is there a way to tweak the circuit to get proper transient protection without exceeding voltage limits? Maybe adding a comparator to the reverse blocking diode to detect transients and quickly shutdown the reverse blocking mosfet?
Are there compact alternatives to the TPS25983 that could fit within my space constraints?
I chose the TPS25983 mainly for its small size and integration with the reverse-blocking MOSFET. But given the space limitations, I'm open to other ideas.
Thanks in advance for any advice!
