Part Number: LM317HV
I need to get a regulated dc voltage but it will have different values depending on a digital setting. For this I had thought about using a DAC. In the case of a switched regulator it is easy to put the output of the DAC through a resistor to the FB pin but in the case of the LM317HV it is not so trivial. Is there any application note on this?
thank you,
Jorge
