LM4050-N: LM4050BIM3-2.5/NOPB vs LM4050BEM3-2.5/NOPB vs LM4050QBEM3X2.5/NOPB Differnce between them
Part Number: LM4050-N
Hi Ti,
I want to know the difference between 1) LM4050BIM3-2.5/NOPB 2) LM4050BEM3-2.5/NOPB and 3) LM4050QBEM3X2.5/NOPB.
Please correct me if my understanding is wrong,
LM4050BIM3-2.5/NOPB  -Industrial Temperature Range −40°C to 85°C.
LM4050BEM3-2.5/NOPB - Extended Temperature Range −40°C to 125°C.
But in datasheet, They have given data for LM4050BIM3, LM4050BEM3 for Industrial temperature range as well as Extended temperature range  as shown in below.
Which data do i need to consider for LM4050BIM3-2.5/NOPB and LM4050BEM3-2.5/NOPB, How will i differential whether it is for industrial or extended.
  • Hi Rakeshkumar,
    Thanks for your question!
    This is a mistake in the datasheet that we will look into. The LM4050BIM3-2.5/NOPB is for the industrial temperature range and the LM4050BEM3-2.5/NOPB is for the extended temperature range. They are correctly listed at the bottom of the datasheet under the packing information section.
    The LM4050QBEM3X2.5/NOPB is the automotive grade part with the same specifications as the LM4050BEM3-2.5/NOPB.
    I hope this helps!
    Andrew Li
