In my regulator, the input voltage is 3.3V and required output voltage is 1.8V. Please go through my schematics and provide feedbacks for it
Thanks and regards
Abhishek
Thanks and regards
Abhishek
Hi Bobby,
Can you please verify my schematics for TPS75433QPWP.
Abhishek
Hi Abhishek,
I have reviewed the schematic for U36 and following are my comments:
All the components have been marked as DNP, but I am assuming you are placing all of them as per the schematic.
1. Cout: Your cout is significantly higher than Cin. So, when the device starts up, due to the higher inrush current, the part might go into current limit. Please be aware of this.
2. Cout ESR: Please follow the recommendations in Page 15 of the datasheet regarding ESR of the output cap.
3. Sense (Pin 7): Since this is a fixed device, Pin 7 is a sense pin. Please see the following recommendation from datasheet
Bobby
