LM74720-Q1: Boost converter operation condition
Part Number: LM74720-Q1
Hi team,
I have a question about an operating condition of boost converter in LM74720-Q1.
Below is from datasheet page 10, functional block diagram.
You can see Voltage on "C" pin is compared against 2.5V threshold and Ored with EN signal.
Does it mean even if the part is disabled, Boost converter will turn on when the voltage at C reaches 2.5V, correct?
In other words, even if voltage at C pin is below 2.5V, Boost convert will start switching when EN signal is applied?
regards,
