TPS61199: spec check
Part Number: TPS61199
Hi
The customer's screen has a set brightness level. When the screen brightness is set to level 0, and the screen is turned off and on again, the screen brightness will be brighter than level 0, but darker than level 1. The screen starts to flash, and during the flashing process, the brightness will gradually return to level 0. The entire process lasts for about 20 to 30 seconds.
UTI_Repeater_TPS61199PWP_8 inch panel.pdf
